I need alil advice I wanna swap a 07 f22c in my ap1
What all would I have to change or modifie to make a 2007 f22c longblock in my 2001 ap1 in run it off my ap1 ecu and ap1 transmission. Please help! I'm currently not running a secondary air injection pump.
I know I'd have to strip motor down to just longblock and re dress it back up with 03 parts put my 03 valve cover on. 03 intake manifold+fuel rail+injectors. All other 03 sensors. Change over my pulse wheel. Anything else I'm missing. On my car I'm currently not running abs/ac/cruise control/no secondary air injection pump. So it should swap over pretty easy?
Intake manifold, throttle body, fuel rail/injectors etc, crank sensor, crank sensor wheel, and valve cover. You will throw a check engine light for the air pump stuff.
If its a good deal go for it!
im alrighty throwing a code for my straight pipe and not having my secondary air pump so that's no biggy
so parts ill be swapping over to the 2007 off my 2003 are....
2003 full intake manifold with fuel rail and injectors.
2003 valve cover with both cam sensors.
2003 Trigger wheel and all other 2003 sensors that are on my Long block.
2003 end plate.
then of course new intake manifold gasket and valve cover gasket. and I have Honda bond for the timing cover gasket and the oil pan gasket.
anything else I am for getting?
2003 end plate.
AWWHITE s2k
Member S2000 Classifieds and For Sale
04-05-2013 07:08 AM
