S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Injectors sizes
Old 05-21-2017, 09:59 AM
ap2yellow's Avatar
Default Injectors sizes
Hi was looking for some help for some injector sizes for my build. Are the rdx injectors enough or do I need bigger? Running a 2.4 stroker that is being put together currently. Any input would be appreciated.
Old 05-26-2017, 07:52 AM
K20iVTEC's Avatar
No need to upgrade at all. Stock injectors should be more than enough...
Old 06-05-2017, 08:14 PM
c32b's Avatar
what's the expected output?
Old 06-14-2017, 11:04 AM
s2000Junky's Avatar
Stock injectors are good to 300-310whp in my experience utilizing them with a base kit supercharger.
Old 06-14-2017, 09:53 PM
flanders's Avatar
At stock fuel pressure and 100% duty the stock injectors theoretically supports up to 233whp.
Old 06-15-2017, 12:55 AM
ap2yellow's Avatar
Thanks for the replies. Went with ID injectors
Old 06-15-2017, 08:51 AM
s2000Junky's Avatar
Great injectors. I ran ID1000 on the stock engine for some time during my FI transition. Runs good as stock.
Old 06-19-2017, 08:33 AM
K20iVTEC's Avatar
I made 240whp and my injector duty cycle doesn't even touch 70%.... buying injectors with a n/a setup is a waste of money
Old 06-19-2017, 10:23 AM
flanders's Avatar
What fuel pressure did you use?
Old 06-19-2017, 10:27 AM
s2000Junky's Avatar
What ever it takes. Fuel pressure is free. I run 85psi idle pressure on my stock injectors. You wont need to run that high if you can increase injector duty, I cannot because I'm running a factory ecu.
Quick Reply: Injectors sizes
