Go Back  S2KI Honda S2000 Forums > Special Interest > S2000 Naturally Aspirated Forum
Reload this Page >
J's Racing C304 SUS Exhaust 60RS PLUS
S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Old 04-13-2018, 08:25 PM
Default J's Racing C304 SUS Exhaust 60RS PLUS
Has anyone tried this exhaust? Can you share your experiences? If you have weight and db to share that would be awesome as well!
Thanks in advance!
phiaceko is offline
Old 04-17-2018, 12:54 AM
RolanTHUNDER's Avatar
No experience with the 60RS but I have experienced the 70RS in stainless steel and it sounds great. Might be a little raspy for some with a test pipe but if you like that then you would like the sound. Awesome sound and feeling in VTEC! Saves at least 15lbs over the stock system. maybe even more than that. The 60RS should have the same character overall but a little less aggressive up top and less bassy down low...
RolanTHUNDER is offline
Old 08-09-2018, 09:34 AM
I have a 60RS and it sounds great. The quietest single you can find; not too different form OEM at idle, yet screams on the cam. Great build quality as well.
One thing to make sure of is the fitment 06+. They rub on the exhaust tunnel and a bit on the rear under-brace. I'm not willing to bash the exhaust tunnel, so I'll probably have to grab something else.
ApexA is offline
Old 08-09-2018, 11:24 AM
Definitely not the quietest single, please don't spread misinformation.
Scigheras is offline
Old 08-10-2018, 08:39 PM
S2kAndTheAnt's Avatar
I agree I can think of like 5 exhausts that are more quiet than the J's
S2kAndTheAnt is offline
Old 08-16-2018, 12:58 PM
lol seriously, like I truly own the quietest single possible. Origin fab, dual resonated + helmholtz 63.5mm. I've had experience with just about all of the majors.
unclebobby is offline
Old 08-20-2018, 06:25 PM
I had the 60rs dual with a berk hfc on my 06 and it sounded insanely good at high rpms but that was about the only good thing.
Here's my pros.
1. sounds insanely good at high rpms
2. The dual mufflers are not straight theyre angled to the sides which looks unique
3. After a tune I did feel slightly more power
Cons:
1. 06 and above will rattle alot because it hits the exhaust tunnel
2. blue tips faded very fast so I removed the blue finish and left it stainless steel
3. exhaust piping cracked in multiple spots primarily where the dual mufflers connect in the rear but if you get a single you shouldnt have this problem.
4. YES it drones a good amount anywhere under 4k rpms so don't believe those that say it doesnt.
If you're looking for straight out performance and crazy vtec exhaust notes and are ok with some drone its the one for you 100% but if you daily drive your car Id look for something with less drone. I replaced it with a tanabe medallion which gives no performance at all but I no longer have any drone or have to deal with rattles but to each their own.
RosarioII
rosarioII is offline
Old 09-03-2018, 10:14 PM
Is the Origin fab portion of it 70mm? Do you have pictures of your setup?
jiepo is offline
Old 09-04-2018, 06:50 AM
My entire exhaust is 63.5mm from the Header V band back. You can barely tell my car is running when highway cruising at 65mph. WOT is a whole NOTHER story.
Old 09-04-2018, 06:43 PM
Dam, that looks amazing.
jiepo is offline
Quick Reply: J's Racing C304 SUS Exhaust 60RS PLUS
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
