k-swap adapter and flywheel options
Hi guys, I searched and couldn't find much data on adapters and flywheels, everyone seems to be using the Ballade Sports solution.
What are the current options for installing a K series engine into an S2000?
Currently, I know of only Ballade Sports that makes a transmission adapter and flywheel. Are there any other options out there right now?
Lastly for the people doing K Swaps what Oil Pans are you using?
Thank you
Thank you
Thanked 0 Times
in
there's a shop called 2nr. they are facebook and from what 2nr told me, they are way better than ballades adapter. long story short get the 2nr adapter, which is also cheaper than ballades. source your other parts seperately because you can find them cheaper than if you bought them from ballade. ive done my search and almost pulled the trigger on a k but i ended up replacing my f20 to a f22 instead. if i had the patience, i would of went k. as for flywheel, competition clutch is the only company that makes this hybrid flywheel, correct me if im wrong. good luck
I Think clockwise do some sump plates in the UK
for adapter on egay item 252567014434 from Potugal no idea of the quality
also went for another F20 was easier faster and less £s
