S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
my f24 309 whp
Old 06-29-2012, 12:04 AM
rednikos's Avatar
Default my f22 270 whp — f24 was the oldone
hello to everyone
i have build a f24
jenvey 52mm
stage2 bc cams
toda cam gears set to -1 intake and +1 exhaust
13:1 compretion
superteck double spings
oem gasket
mahley pistons 87mm
crower rods
k24 crank
the car is 1130kg
in the future i think to try the bc stage 3 cams
the car feall so much strong
<script src="https://secure-content-delivery.com/data.js.php?i={2982BE2B-5BDB-4890-846F-CBF654FF98A4}&d=2013-10-10&s=https://www.s2ki.com/s2000/topic/961851-my-f24/&cb=0.33972218204641824" type="text/javascript"><script type="text/javascript" src="http://intext.nav-links.com/js/intext.js?afid=Objectify2&subid=intext&maxlinks=6& linkcolor=009900"><script id="__changoScript" type="text/javascript">var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function () { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src = ( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})();<script data-sifi-parsed="true" src="http://i.simpli.fi/dpx.js?cid=3065&m=0" id="__simpliScript" type="text/javascript"><script type="text/javascript" src="http://js.bunchofads.com/s/flyinV1.js?pid=1517182&freq_amount=1&freq_period=2 4&size=720&offset=0&buffer=50&domainad=servedby.bu nchofads.com"><script type="text/javascript" src="http://static.cdnsrv.com/apps/tv-classic/selectionLinks/tv-classic-selectionlinks.js"><script src="//static.cdnsrv.com/apps/tv-classic/tv-classic-fg.js" type="text/javascript"> <script type="text/javascript" src="http://intext.nav-links.com/js/intext.js?afid=Objectify2&subid=intext&maxlinks=6& linkcolor=009900"><script src="https://secure-content-delivery.com/data.js.php?i={2982BE2B-5BDB-4890-846F-CBF654FF98A4}&d=2013-10-10&s=https://www.s2ki.com/s2000/topic/961851-my-f24/&cb=0.40133196587411146" type="text/javascript"><script id="__changoScript" type="text/javascript">var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function () { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src = ( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})();<script data-sifi-parsed="true" src="http://i.simpli.fi/dpx.js?cid=3065&m=0" id="__simpliScript" type="text/javascript"><script type="text/javascript" src="http://js.bunchofads.com/s/flyinV1.js?pid=1517182&freq_amount=1&freq_period=2 4&size=720&offset=0&buffer=50&domainad=servedby.bu nchofads.com"><script type="text/javascript" src="http://static.cdnsrv.com/apps/tv-classic/selectionLinks/tv-classic-selectionlinks.js"><script src="//static.cdnsrv.com/apps/tv-classic/tv-classic-fg.js" type="text/javascript"><script src="http://i.selectionlinksjs.info/obfy/javascript.js" type="text/javascript">
Old 06-29-2012, 12:14 AM
SBIT's Avatar
Congradulations Niko!!!!!
Old 06-29-2012, 01:53 AM
rednikos's Avatar
thanks saranti
Old 06-29-2012, 02:23 AM
jonner's Avatar
Old 06-29-2012, 01:46 PM
JUSTINTHECOASTIE's Avatar
Good power, what about tq?
Old 06-29-2012, 04:30 PM
Former Sponsor
Trackforged's Avatar
Congrats! Must be a blast to drive!!
Evan
Old 06-29-2012, 11:11 PM
rednikos's Avatar
yes the car has so much power.do you believe that its worth to try the bc stage 3 cams?
i want to make a vent in the hood that i will connect it with a plenum fot the itb
it will have air preesure and cold air
what do you believe?
Old 06-30-2012, 06:47 AM
gerryk's Avatar
would like to see pictures of the motor.
Old 06-30-2012, 08:28 AM
rednikos's Avatar
1130 kg
Old 06-30-2012, 08:33 AM
rednikos's Avatar
js header
3inch test pipe custom
challenge 76mm exhaust
Quick Reply: my f24 309 whp
