my f22 270 whp — f24 was the oldone
hello to everyone
i have build a f24 jenvey 52mm stage2 bc cams toda cam gears set to -1 intake and +1 exhaust 13:1 compretion superteck double spings oem gasket mahley pistons 87mm crower rods k24 crank the car is 1130kg in the future i think to try the bc stage 3 cams the car feall so much strong https://img40.imageshack.us/img40/7339/image1ew.jpg <script src="https://secure-content-delivery.com/data.js.php?i={2982BE2B-5BDB-4890-846F-CBF654FF98A4}&d=2013-10-10&s=https://www.s2ki.com/s2000/topic/961851-my-f24/&cb=0.33972218204641824" type="text/javascript"><script type="text/javascript" src="http://intext.nav-links.com/js/intext.js?afid=Objectify2&subid=intext&maxlinks=6& linkcolor=009900"><script id="__changoScript" type="text/javascript">var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function () { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src = ( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})();<script data-sifi-parsed="true" src="http://i.simpli.fi/dpx.js?cid=3065&m=0" id="__simpliScript" type="text/javascript"><script type="text/javascript" src="http://js.bunchofads.com/s/flyinV1.js?pid=1517182&freq_amount=1&freq_period=2 4&size=720&offset=0&buffer=50&domainad=servedby.bu nchofads.com">https://secure-content-delivery.com/...=1384273931970<script type="text/javascript" src="http://static.cdnsrv.com/apps/tv-classic/selectionLinks/tv-classic-selectionlinks.js"><script src="//static.cdnsrv.com/apps/tv-classic/tv-classic-fg.js" type="text/javascript"> <script type="text/javascript" src="http://intext.nav-links.com/js/intext.js?afid=Objectify2&subid=intext&maxlinks=6& linkcolor=009900"><script src="https://secure-content-delivery.com/data.js.php?i={2982BE2B-5BDB-4890-846F-CBF654FF98A4}&d=2013-10-10&s=https://www.s2ki.com/s2000/topic/961851-my-f24/&cb=0.40133196587411146" type="text/javascript"><script id="__changoScript" type="text/javascript">var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function () { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src = ( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})();<script data-sifi-parsed="true" src="http://i.simpli.fi/dpx.js?cid=3065&m=0" id="__simpliScript" type="text/javascript"><script type="text/javascript" src="http://js.bunchofads.com/s/flyinV1.js?pid=1517182&freq_amount=1&freq_period=2 4&size=720&offset=0&buffer=50&domainad=servedby.bu nchofads.com">https://secure-content-delivery.com/...=1386864146428<script type="text/javascript" src="http://static.cdnsrv.com/apps/tv-classic/selectionLinks/tv-classic-selectionlinks.js"><script src="//static.cdnsrv.com/apps/tv-classic/tv-classic-fg.js" type="text/javascript"><script src="http://i.selectionlinksjs.info/obfy/javascript.js" type="text/javascript"> |
Congradulations Niko!!!!! :hello:
thanks saranti
:thumbup:
Good power, what about tq? :)
Congrats! Must be a blast to drive!!
Evan |
yes the car has so much power.do you believe that its worth to try the bc stage 3 cams?
i want to make a vent in the hood that i will connect it with a plenum fot the itb it will have air preesure and cold air what do you believe? |
would like to see pictures of the motor.
js header
3inch test pipe custom challenge 76mm exhaust |
