NA 2.4L
NA 2.4L
Hello! I am thinking of building a NA with the 2.4L stroker kit! the one with the 99mm crankshaft, Crower MaxiLight rods και Mahle FRM compatible pistons, using a AEM v2 as an ecu! I am thinking of using ITB instead of a 70mm throttle body! I need some opions of people who may have used the itb or the throttle body cause ITB are quite expensive!
I am using the S2000 for drifting (as an amatuer) and doing some time attack events!
Ive used Mahle pistons and CP piston They both work great but you can save some money with CP. also kindler ITB's are the way to go, HP pick ups are around 20hp. My 2.4 stroker kit with ID 1000 made 280hp on a dyno jet.
I'm with you on the stroker, but read carefully about the disadvantages about ITB's. A actual dedicated race car I think it's great. I wouldn't daily one as running a filter kills performance so I've read.......
