NA High HP Project - What else can be done?
We prepared an NA setup on our customer's 2009 S2000
It is a Euro-Spec S2000, so it originally had a 2.0lt engine in it Here is what we have in the engine so far: OEM 2.2 Crankshaft InlinePro Rods CP 12.5 CR Pistons with X Forging Darton Sleeves InlinePro Stage 3 Camshafts Toda Adjustable Cam Gears Supertech +1mm Intake and Exhaust Valves Supertech Valve Sprigs and Titanium Retainers ARP Headstuds Toda Lightweight Pulley Set PLM Header Amuse 63mm Titanium Single Exhaust Custom Intake Half Size Radiator Hondata Intake Manifold Gasket Skunk2 DBW Throttle Body Hondata FlashPro Fully Ported and Polished Head Ported and Polished Intake Manifold HKS Fuel Regulator Injector Dynamics 725cc Injectors AEM Methanol Kit 4.44 Final drive set Carbonetics LSD DSS aluminum driveshaft Brakes Spoon CC Stage4 / lightweight flywheel Greddy oil catch tank Mugen thermostat Skunk2 radiator hose set Master bushing set Brakes Spoon Suspension BuddyClub On E50 fuel, the car made 273hp on a Dyno Dynamics Dyno Considering that Dyno Dynamics measures about %10-12 less, We are at 300hp The numbers are NOT WHP Gutted to 2600lbs NOW, to the NA Experts, what else can be done on this car to increase the horsepower? Some shots of from the build http://peakgarage.net/sites/default/...105_193554.jpg http://peakgarage.net/sites/default/...105_193630.jpg http://peakgarage.net/sites/default/...803_175248.jpg http://peakgarage.net/sites/default/...803_175328.jpg http://peakgarage.net/sites/default/...107_193502.jpg http://peakgarage.net/sites/default/...107_193610.jpg http://peakgarage.net/sites/default/...107_201521.jpg http://peakgarage.net/sites/default/...108_183854.jpg http://peakgarage.net/sites/default/...110_165422.jpg http://peakgarage.net/sites/default/...110_165036.jpg http://peakgarage.net/sites/default/...110_165103.jpg http://peakgarage.net/sites/default/...110_165134.jpg http://peakgarage.net/sites/default/...110_165211.jpg |
Very nice.
Dyno graph? I wouldn't say DD reads less, it reads accurate. |
stock ones read 213-218hp
will post dyno graph tomorrow |
Yep same over here on DD, I'd say that's genuinely what the car puts out :thumbup:
Originally Posted by MB
(Post 22678131)
if a stock s2000 is 240hp, then this is around 300hp :) |
From my point of view with this setup you need at least 76mm exhaust diameter and 80mm piping diameter with a little bigger length of the intake piping arm.
Also a additional + would be a bigger intake manifold if you have the skills to fabricate one own your own or buy an aftermarket. Just my 0.02 https://www.s2ki.com/s2000/public/st...t-tip-wink.gif PS. Can you post a video of the car? PS2 What ECT do you get with this radiator? |
I'd agree on the exhaust.
Im using a 70mm T1R and Berk 70mm high flow cat. |
post up the graph.
Who did the head? There is always some power in the head.. and i'm not sure why your cylinder head guy went with +1mm valves. You have to do alot of work to put a real big valve port in these heads. the stock size will make 300hp. If you have good fuel you can always just yank the head, mill it 20thou or so, that will put you at closer to 14:1 compression. get a custom header made with a megaphone/reverse cone and goto a 3inch exhaust |
We already had a 70mm exhaust on the car. The car made that power with the 70mm
We just put the 63mm exhaust on the car to save weight. That was the only titanium we had on the car So you guys think a 76mm will be even better? We might consider a bigger intake manifold like inlinepro What is a megaphone/reverse cone header? Should we change the intake? I will try to post some videos |
3 inch exhaust really is worth it.
as far as the header goes, there is a ton of info out there burns makes pretty much the best stuff on the market http://www.burnsstainless.com/mergecollectorsmain.aspx The intake you have looks good to me, it might be on the small size though. A 3inch intake will work well up to about 210-220 to the tires, beyond that you'll need a long 3.5 or 4 inch intake tube. |
