NA "stroker" motor questions,
Hey guys... I'm picking up a totaled 03,, I've got a 00, with almost 130,000 on it,, still runs like a TOP, but thinking of building up the 03 motor over the winter, and then swapping it into my 00, then selling off my 00 motor,,, Here's my questions,,, I've been reading the article about building a S2K, "stroker" motor by using the slightly modded Prelude crank, rods, etc,,,, By boring the motor .030 over, and the Prelude parts,,, it's comes out to right under 2.5 liters,,, what cams should I be looking at?... are the OEM's OK for this combo?... or should I be considering some by BC???,,,, I'm NOT trying to build an all-out, "Hot Rod",,, just a nice, simple, RELIABLE, daily driver combo,, Maybe a larger throttle body, etc,, like I said,, simple, reliable, "OEM" stroker motor,,, By using the 03 ECM,, I'll still have the higher AP1 redline, but the added cubes ought to gimme the lower end grunt of the AP2,,, What suggestions do you guys have?... Thanks
I'm thinking you might want to do a lot more research and head over to the NA or JDM tuning forum.
typically, stroker setups arent that reliable.. |
typically, stroker setups arent that reliable.. http://www.turbomagazine.com/tech/0609turp...uild/index.html |
Take the time and read through this thread. It will give ou all the info you need on what you have to do to make this work....https://www.s2ki.com/forums/index.ph...f=148&t=538548
:) no prob, good luck.
