Need to buy a new Engine for my S
you cant remove the crank w/the motor in the car w/o doing a ton of extra work. Trans, clutch and flywheel would have to come out.
Chances are if you messed up a main bearing the block is toast anyway. $4000 for a new motor installed is a pretty good price, especially w/a warranty.
Banned
You cant pull the motor and leave the tranny.
I was saying, if they try to change just the crank with out pulling the block it'd be way more work than its worth to get the crank out.
You cant change the crank with the transmission in the car.
There was a thread around here with the cost of an oem new short block and it's 3200 for 06-09 I believe? If you can do the labor yourself, that's probably the best route. Get yourself a Helms and go at it.
Russ Watts
07-04-2013 02:24 PM
