New GearTech NA build 2.25lt
Hello Guys, we are just starting a new engine for a customer who does lots of mountain driving and some autocross events. The goal was not ultimate HP like some 300+whp engines we have built in the past but max possible durability and the ability to rev at or near 9000 to retain the engine's character and S2k's special characteristic. We are starting engine assembly tomorrow as we just got some final bits and parts and would like to share with the community this build process. Some initial specs (I will regularly be updating this post as the build progresses until final dyno day).
Engine Block F20c2 block resleeved (Golden Eagle) -> 89mm 89mm JE pistons (perfect skirt) Crower maxilight rods with AMS5844 special bolts Toda Racing F22C crankshaft (90.7mm) Toda oil pan Cylinder head 4p CNC Toda C camshafts and valvetrain Toda camgears AT Power shaftless ITBs 52mm Peripherals Tegiwa header HKS 75mm exhaust 70mm test pipe Ultratech PRO EMS v2 ECU Subaru WRX STi injectors (565cc) J's Racing ITB box and intake The whole car is in the process of complete restoration and apart from engine, we have rebuilt the gearbox (oem parts + 1.206 secondary drive) and the differential (OS Giken LSD). The car just also got a paint blue to restore the shiny monte carlo blue, complete silent block kit, ohlins coilovers, big brake kits, rear wing etc. Stay tuned! |
Good god. TODA parts = no expense spared.
Is their crank made by them or is it just a modified OEM crank? |
Very cool, please share as much as possible on the build process :)
Originally Posted by Charper732
(Post 24588326)
Good luck with the project Gzob!Sounds perfect 2,2+itbs+9000revs!!I'm sure it's gonna rock!!Give as much infos as the project goes on.
Looking forward to the build. Sounds like an excellent parts list. Have you decided what mfg's bearings you'll be using? Any additional oiling/lubrication solutions apart from the oil pan?
Originally Posted by fly_S2K
(Post 24588689)
No extra oiling solutions for the moment and since we are not running slicks (but high performance Federal FZ-201), the engine will be OK with the baffled oil pan and 'mortal' rev limit. |
While engine is blueprinted, some misc photos from the build:
https://cimg5.ibsrv.net/gimg/www.s2k...a11f9a188.jpeg Rebuilt differential with OS Giken LSD and j’s solid distance collar. Stock 4.1 FD https://cimg8.ibsrv.net/gimg/www.s2k...5ad6804d4.jpeg Rear differential mounts https://cimg6.ibsrv.net/gimg/www.s2k...dee7ef5e7.jpeg Spoon rigid collars. |
Progressing:
https://cimg7.ibsrv.net/gimg/www.s2k...1e99ea0709.jpg JE Pistons + Crower rods https://cimg8.ibsrv.net/gimg/www.s2k...c3f904412b.jpg Special Crower ARP bolts |
