New GearTech NA build 2.25lt
We have used Toda B's in the past on an F22c with Toda pistons and typical i/h/e. It performed very well, as far back as I can remember, 262 hub HP on a dynapack.
You don't notch the valve guides, you notch the rockers for the primary and secondary (aka non-vtec) exhaust cam lobes. If you don't do this you will cause a lot of damage.
Correct. We will make sure the lobes clear the rockers when we assemble the head. This is a couple of weeks away though. Believe it or not, we are running low on some main bearing colors and honda Greece does not stock them as well. So we are waiting for some bearings to finish the bottom end. For the book, we need the same bearings in all five mains (green-yellow). I guess Toda chooses the best and most consistent cranks from Honda. We also sent a block to GE with the same main bearing code. This means that we could get away with ACL as well but customer requested oem honda bearings.
A Good Customer, has values regarding oem bearings a.+ from me
