NGK Iridium IX BKR8EIX 2668 - power down?
Dont mean to thread jack but I dont feel like starting a new thread. I heard 1-step colder plugs usually range from an add to hp (75-100hp) before you start going steps colder. I was thinking of doing a 1-step colder and heard NGKs are the "best".
Are these the 1 step colder? http://www.amazon.com/NGK-BKR8EIX-Iridium-...g/dp/B001B6VUTM
Will work fine with my setup? I plan on getting a header soon and also will be tuning in summer. (mods are in sig)
Originally Posted by Stealth Operator,Apr 5 2010, 09:20 PM
There is not much point using a colder plug unless there is substantial modifications to require it.
When I got tuned with my full bolt-on setup, the tuner suggested to use 1 step colder plugs but they definitely didn't work out too well. The car ran normal to about 5000 RPM and then after that, the car would just sputter and hesitate. He even rechecked the gapping to make sure they were correct, and the gapping was fine.
Swapped the original plugs in again and the car ran great.
Andre
Originally Posted by dan_uk,Apr 7 2010, 08:22 PM
ok I changed plugs and I'm happy with it now will get it on a real dyno soon
might just have been the warm day and the oil blowby making it seem a bit sluggish
Andre
Andre
Banned
a change of one way or the other as far as heat range goes is not likely to make a difference on a single dyno pull for a mostly stock car.
if the plug is too hot then you will get some pre-ignition or detonation, it will probably take a few pulls on the dyno to see that.
if the plug is too cold, it will foul itself out under normal driving conditions.
If you drive like grandma, keep the stock plug in it. If you drive like an ass go one step colder, the plug will last longer.
If you swap to a colder plug you either got the wrong one or a bad set of new plugs. New plugs should always pick up power over old even if the heat range is off
If you were to do back-to-back dyno tests with a brand new set of cold plugs and a brand new set of stock plugs, you won't see any difference. However, if you run the cold plugs for a couple thousand miles, dyno test it, then run the stock plugs for a couple thousand miles, then dyno test it again, you will likely see a difference in power. Over time, the colder plugs will likely wind up causing the ECU to reduce the amount of knock retard, which will lead to more power.
The reason why I believe this is because I've seen this when I datalogged my friend's '02 S2000 against my '02 S2000 (with colder plugs) years ago, and also when I datalogged my brother's '06 S2000 against my '08 S2000 (with colder plugs). In both cases, my S2000's were running more ignition advance by a couple degrees.
BTW, here is a graph from the datalog of my '08 and my brother's '06. The red curves are from my car, and the blue from my brother's. The top lines are the ignition advance, and the lower lines are the knock retard. As I said above, I believe the reason for my car having less knock retard is due in large part to my colder plugs.
BTW, ignore the top chart (Knock Level).
Originally Posted by MBHs2k,Apr 15 2010, 04:32 PM
When you install new plugs dont you have to give it some time for the car to adapt to the new plugs? i thought i have herd that before.
