OEM Heat Shield for Berk High Flow Cat ?
Can I just refit the OEM heat shield over a 63.5mm Berk High Flow Cat? If not in stock form what do I need to do?
Thanks, I want to keep as much heat from the cat away from the passenger compartment as possible.
-- Chuck
-- Chuck
you'll have to have the OEM heat shield modified to fit the Berk HFC. it's definitely worthwhile. i have a Berk, and there's a ton of heat coming up through the driveline tunnel.
Thanks. This is stainless so I'll need it TIG welded I assume.
I've read where the head shields can just be bolted together and they'll stay on the cat. For a while. I was thinking maybe wrapping the end areas where the shields narrow down with exhaust insulation tape and then clamping the heatshields together. Anyone try this? (I'm sure I can get tabs made and welded on, just looking for alternates.)
-- Chuck
-- Chuck
-- Chuck
-- Chuck
-- Chuck
-- Chuck
