power curiosity
hey guys im going to run a set up with
2.2 litre toda stroker kit toda spec c cams with retainers, valve springs toda quad throttle bodies rc injectors 550cc sard fuel regulator aem 1052u ecu toda headers and cat back with test pipe (already on the stock engine atm) m&m carbon fibre cover for itbs (in australia very illegal with it off lol) has anyone done anything similar to this if so what results did they get be great help thanks in advance |
i'm sure anyone with an ap2 will be similiar to your 2.2 stroked, idk about toda cams most of what i've read say they are bad, but they might have fixed that now, quad throttle bodies or ITB's will give you lots and lots of midrange and better throttle response depending on tune, idk about the injectors or aem, should be fine but i'm basing that on nothing, toda header is a great one so ddint go wrong there.
First, it's header, not headers, there is only one on an inline engine. Sorry, it's a pet peeve ... I'm a prick.
Second, look up ASM's specs, they're running a setup very similar to yours (bigger exhaust), and I think they have the B spec cams, not 100% sure though. I think you have to be running forced induction of some kind to get a benefit from the C specs. EDIT: For reference, ASM is getting 291whp out of theirs. |
http://minds-farm.blogspot.com/2008/01/asm...ecial-spec.html
this is the old 2.2L they had though.. now they run a 2.4L which most certainly has more power.. |
All the big Japanese tuners use the Spec A2 cams in their race motors. The Bs and Cs just don't make much if any additional power and where on the motor much more. You would probably be in the 250 whp area and much more area under the curve.
so spec c cams arent gonna benefit as much if its just staying N.A still?
Also, keep in mind that peak power means nothing. The area under the curve will tell you everything.
I believe there is a member on here that has ITB's, the supporting mods, and an AEM EMS; he has about 220whp if I'm not mistaken. While 220 peak horsepower may sound weak, he said he would constantly pull on modded S2000's, due to his massive mid range. I'm not sure if it is the same member or not, but another person with the same mods as listed above ran a 13.1 1/4mile time. Both of these cars (if they aren't the same), had completely stock motors. If you were so inclined, you could build your own 2.4l Stroker motor and add ITB's on it (Along with the supporting modifications of course). |
