S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
QUIET performance mods?
Old 07-20-2013, 08:31 AM
petawabit's Avatar
NA LS swap
Old 07-20-2013, 09:55 AM
Cody Red's Avatar
I always felt like the stock header was kinda loud, so not sure if that's something you should pick up. Also because stock header is already good.
Old 07-21-2013, 08:30 AM
FluKy15's Avatar
Just add a 60mm testpipe and you have the best gains possible for staying quiet still. You can also lookup the "UK exhaust mod", some in my local area are doing this, to add a little more sound to a stock exhaust.
Old 07-21-2013, 10:31 AM
s2000Junky's Avatar
You got a leak or what
Old 07-21-2013, 03:38 PM
GrandMasterKhan's Avatar
The Mugen intake is actually very quiet and makes good power. I had a replica I bought on ebay and I liked it a lot. Highly recommended if you want to make quiet power while looking damn good. It sounds only slightly louder than the OEM airbox.
Old 07-22-2013, 03:45 PM
Cody Red's Avatar
not that kind of loud hah.
Old 07-23-2013, 01:50 PM
thomsbrain's Avatar
My setup sounds nearly the same as stock unless you stomp on the throttle. BC Stage 2 NA cams, K&N FIPK intake, Comptech header, stock exhaust, dyno-tuned on Hondata Flashpro for 226 whp. That's more power than plenty of super loud setups, and it passes California smog tests.
Old 07-23-2013, 03:34 PM
FluKy15's Avatar
For comparison, its always best to post what the stock s2000s put down in the same dyno. For example, the dyno i use the stock s2000s put down 200-203, and i made 215. It gives everyone a general idea of how much was gained. Sone dynos can read higher/lower than others
Old 07-24-2013, 12:37 PM
EVAN&MONICA's Avatar
Originally Posted by petawabit
NA LS swap
Evan
Old 07-24-2013, 12:49 PM
Breaking Point's Avatar
Quiet quality.mugen intake. Gern mid pipe.and whatever axle back you choose. Ems. BC cams. Stroke. Can be a relative quiet and a good hit more powerful than original
Quick Reply: QUIET performance mods?
