I'm beginning to wonder if I should have placed this in the s2000 talk section or something also or instead of here.
So the BC cam's Do make power. Kool
Originally Posted by Croc
(Post 22108420)
i've got those.
my engine is F20C2 with all possible bolt on mods and a tune (vtec at ~5600) could drove only ~20 miles but the car definitely felt punchier at 4-4.5k and up in high gears. 3rd gear is strong all around. the top end felt somewhat rough. maybe becuase quite significant increase in engine noise. looking at logs and Gernby's soft dyno the top end looks not smooth: https://sites.google.com/site/crocwe...res/edyno1.jpg maybe after all keeping stock valve springs is not enough and valves float indeed.... |
thanks for chiming in !!!!
what's the OK range of values? with smoothing at 200 it looks pretty good. with 250 it's almost perfect.... |
(Post 22121462)
Anyone know where the redline on an ap1 would be after installing the bc stage 2 cams?
when i tested the bc2 vs stock my car had similar gains and the tune didnt change at all.
Originally Posted by bbd324
(Post 22805609)
Can I run Super Tech valve train with BC2 cams or does it need to be Brain Crower valve train?
I use the supertech beehive springs for all motor setups. You dont need 100lbs on the seat for NA.
