S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Resonator without perforated tube
Old 06-14-2018, 05:45 AM
TotalBalance's Avatar
Default Resonator without perforated tube
Hi fellow s2ki member,
I have recently removed the perforated tube from the resonator of ASM S-Special exhaust:
Basically the 70mm exhaust pipe is disconnected now with a big resonator having a bit of empty space that will fill up with exhaust gas.
Does anyone know if this setup will have any negative effects?
Old 06-14-2018, 12:58 PM
toztigger's Avatar
increase turbulance, and increase back pressure as flow isnt optimum anymore, might lose some power
Old 06-14-2018, 02:29 PM
noodels's Avatar
Yes a big 0 from me..
Its really f**d up the scavenge,frequency & back psi the box as designed for.
Step 2
Replace & help restore > Special ASM -S. design
Old 07-08-2018, 11:34 PM
It did raised the engine pressure by 1 bar. Circuit driving had no issue though, other than the higher engine pressure spew out oil through PCV much more than it used to.
Ended up making my own straight pipe to replace the resonator in all. The sound changed significantly but still not crazy loud as J's 70rr.
Old 07-09-2018, 06:11 AM
Chuck S's Avatar
Received 1,132 Likes on 995 Posts
A more efficient solution.
-- Chuck
Old 07-12-2018, 01:50 AM
RolanTHUNDER's Avatar
Hmm now there's an idea for the stock exhaust...remove its resonator (but leave the Helmholtz in) and hear what it sounds like... should reduce back pressure too based on the above?
Old 07-14-2018, 01:04 AM
dc2-2-ap1's Avatar
Several people have done that in the past. Pretty much everyone instantly regretted the decision. If you want better sound on stock exhaust, just do the U.K. Mod.
Old 07-15-2018, 11:16 PM
Thanks for the heads up. Guessing it became too bassy/droney in car?
the s2k dude
10-12-2010 11:58 AM
FISH22
08-24-2009 12:42 PM
rjones
04-09-2009 04:44 PM
JsRacingS2K
12-19-2008 10:53 PM
djbaiza
08-23-2008 06:36 AM
Quick Reply: Resonator without perforated tube
