Skunk2 intake manifold
#71
#72
So I run an excessive manifold on my K24, The nice thing about them is I can make little changes to it easily it's not a one size fits all. I talked to them and apparently the owner has an S2000 and a manifold is in the works with them. I did the quick math on my K24 and I need a 55mm runner that's 12 inches long (including the head area). I've got a 58mm runner currently that's 11.5 long. So I'm in the ballpark. Those interested in a manifold might be worth dropping a bug in his ear to see if you can push the process along. It's nice because it's a very tuneable manifold and you can easily make changes based on what you want.
#74
"The general rule is that you should begin with a runner length of 17.8 cm for a 10,000 rpm peak torque location, from the intake opening to the plenum chamber. You add 4.3 cm to the runner length for every 1000 rpm that you want the peak torque to occur before the 10,000 rpm.
So, for instance, if peak torque should occur at 4,000 rpm the total runner length should be 17.8 cm + (6 x 4.3 cm) = 43.6 cm."
i did the math wanting a peak tq about 1000 rpm before redline for a race motor. On something that gets more street miles you might want it lower then that. But without having cuved tubes your not gonna get a runner much longer then 12 inches in that engine bay, your just out of space.
f20kills (10-28-2016)
#76
I feel I want peak torque somewhere around 5-6krpm. So I measured and even though I read your post...don't be surprised if I did it wrong lol. So from the valve to the back of the plenum was 11.5".
Runners from valve to end of runners was 7.5" I don't have the proper tool to measure the inside width of the runners but my guess is 2.5" with my ghetto measuring
#78
#79
you can use this site to figure out optimum lengths
Calculation Of Intake Runner Length
87mm bore
89mm stroke (f24)
peak tq around 6900
basically means you want 2" (50mm) diameter runners, OEM is 51ish, and 9.5" runners, OEM runners are 7.5", (+2.5" from head) 12" total runner length
The following 2 users liked this post by s2000ellier:
f20kills (10-29-2016),
nemesisryder0627 (12-21-2016)
