S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Skunk2 intake manifold
Old 10-29-2016, 10:09 AM
  #81
flanders's Avatar
S2000ellier do you got the measurements on the Jenvey or OBX ITB's?
Here is a working link Calculation Of Intake Runner Length
f20kills (10-29-2016)
Old 10-29-2016, 04:50 PM
  #82
siik_ap2's Avatar
Originally Posted by f20kills
your link doesn't work but if it makes power that's all I care about at this point lol
ill find out soon enough what I make lol
did you go threw with the tune today?
Old 10-30-2016, 05:35 AM
  #83
f20kills's Avatar
Car was dropped off for mani install. Should be done in a few days. I'll update for sure when I get the results
Old 10-31-2016, 07:00 AM
  #84
Mrsideways's Avatar
I feel I want peak torque somewhere around 5-6krpm. So I measured and even though I read your post...don't be surprised if I did it wrong lol. So from the valve to the back of the plenum was 11.5".
Runners from valve to end of runners was 7.5" I don't have the proper tool to measure the inside width of the runners but my guess is 2.5" with my ghetto measuring
Not back of Plenum, to the end of the runner. So you are at 10 inches it looks like.
Old 10-31-2016, 08:04 AM
  #85
f20kills's Avatar
My runners are 5" on just the mani alone...7,5" to back of valve seat.....regardless car is at the shop lol. I did a baseline a few months back but not sure if they saved the file.
If not ill get another baseline and everything should be done by Thursday at the latest. If I lose power its coming out and selling it same day lol
Old 10-31-2016, 08:08 AM
  #86
snitm's Avatar
Originally Posted by s2000ellier
so the fbm runner is only 5" excluding the head and the plenum, pretty short...
you can use this site to figure out optimum lengths
87mm bore
89mm stroke (f24)
peak tq around 6900
basically means you want 2" (50mm) diameter runners, OEM is 51ish, and 9.5" runners, OEM runners are 7.5", (+2.5" from head) 12" total runner length
Assuming the use of a modified K24 crankshaft, shouldn't the stroke for F24 be 99mm?
What did you put in that webform for "Duration intake valve (degrees)"?
Old 10-31-2016, 09:55 AM
  #87
s2000ellier's Avatar
yeah you're right, i typed 89, but 99 is the stroke
"duration intake valve" is the cam duration, ap1 is 295 / 2
Old 10-31-2016, 12:17 PM
  #88
5.5" without air horns, 9.5" with air horns.
Old 11-03-2016, 07:49 AM
  #89
f20kills's Avatar
Small update. Should be on the dyno later today. Baseline was 249 on this dyno 2 days ago. Ignore the ghetto catch can lines lol..thats temporary :P
BASE DYNO...no FBM dyno numbers yet
RPM is off by 400 for some reason. Shift the power band 500 RPM. My rev limit is 8200.
Old 11-03-2016, 09:10 AM
  #90
Save the dyno files! not the graphs but the drf file, they are stored on the computer
Quick Reply: Skunk2 intake manifold
