skunk2 / S90 throttle body running on a stock intake manifold?
have you guys heard of doing this before?
if so, what was the outcome? should i invest into an aftermarket intake? if i can find one that still makes them that is...
Bump!
So it turns out the s90 idea went the other way as we needed to port the manifold to 70mm- so I was wondering if you guys heard anything on the Venturi Big Throttle Body by Spoon Sports? Guys heard anything on that with a stock manifold?
Also shot in the dark- but would the Balade Sports + TB combo fit nicely even though I have a PWDJDM intake? Only reason I ask is because I heard spacing can be a issue
All test I did on my dyno give about 4whp when upgranding an aftermarket throttle bosy that have a 70mm oulet. I highly recommand to use the civic/integra/accord/prelude tps when using a b serie thottle body. Otherwise the tps need to be modified to reach read of 0% when throttle close.
I will put the picture of the tps difference later
soulsweeper
19
07-16-2012 08:43 AM
WalkingDrunken
05-23-2004 05:56 AM
