Wrapping exhaust manifold
Thank you very much for the photos and your advise!
But only one question...
You can do this mod in "diy / home"????
Can we do the gel coating by ourselves....
Thanks
Thanks
You can definitely do the header wrapping yourself. You will need 1"x50' and 2"x50' to completely cover the header. Use the 1" wrap for the primaries since its all curvy. Wrap tight and take your time. Again, it would be hell of an easier time and it would look 100 times better if the header is shaved.
What about heat wrapping a coated manifold that has a heat shield?
I wouldn't get too carried away with wrapping everything. Thermal wrap is made of cloth which absorbs water. If you get it wet, it keeps the moisture against the metal, causing the exhaust to rust quicker than if it were not wrapped.
Off topic, but I recently wrapped my aem v2 intake arm and it sure made a difference in the amount of heat soak. The arm feels so much cooler than before the wrap. I say wrap it all!
