You think Brian Crower and Skunk2 cams aren't good? real testing here
Since a while I make some test on my Ap2
this winter a customer build a F22C and I let him some of my parts for degreeing and take pistons to valve/valve to valve clearance.
here is the build
F22c sleeved
piston wiseco 87.5mm cr 11.9
race bearing acl
Fully balanced
Ferrea 5000 valves
Ported head
Skunk2 Pro series Springs/retainers/base
Brian Crower Stage 2 cams
Skunk2 Stage 2 cams
Skunk2 Pro series Cam gears
66mm custom throttle body
Stock modded air box with 3.5'' aluminum tubing
Hondata Kpro
Fluidamper crank pulley
PLM header
Invidia test pipe
T1R 70mm catback
ID1000 injectors
poulie de crank fluid damper
we passed 13hours on my dyno to test cams settings, change cams, and tune all fuel/ignition each times
OEM AP2 cams, compared to Brian Crower Stage2
video here
https://www.youtube.com/watch?v=_EvZ...ature=youtu.be
here is the build
F22c sleeved
race bearing acl
Fully balanced
Ferrea 5000 valves
Ported head
Skunk2 Stage 2 cams
Hondata Kpro
PLM header
Invidia test pipe
T1R 70mm catback
ID1000 injectors
video here
the last dynosheet have all those detail wrote beside the run numbers.
both cams were ajusted on all tests
Op, what were the torque numbers?
Hi
I have very similar mods:
f20c
Wiseco 88mm 11.9:1
K1 Rods
Darton Sleeves
Skunk 2 stage 2 cams
K&N FIPK intake
J's Racing header
test pipie
Went to dyno yesterday, were able to squeeze only 220HP
Considerations:
Running OEM exhaust
Hot day as hell.
f20c
Wiseco 88mm 11.9:1
K1 Rods
Darton Sleeves
K&N FIPK intake
J's Racing header
test pipie
Considerations:
Running OEM exhaust
Hot day as hell.
