i Need to replace my KW V3 coilovers (dilemma)
check page 3. i need your opinion on the condition of my brake disc
after many years of using them i got one of my front shocks fail and oil leaking from most sides. i cant revalve them where i live so im going for a full replacement. the dilemma im facing is that im on a tight budget. i dont want to exceed $2000 by any means and my car has now retired from street duty and ill use it solely for track and auto x.
current setup is 8" 17 front wheels and 9" 17 rear wheels and i usually use semi slick rubber 225/45/17 front and 255/40/17 rear.
the only street trips i might take are going to and back from the track. my car is supercharged with 380whp
i was thinking of getting these: Greddy x KW coilovers (9k spring rates square)
GReddy X KW Performance Coilovers - Honda S2000 00-09 Evasive Motorsports
but im afraid they are too street oriented .. can these perform sufficently on the track?
then i bumped into there and they look like a bargain but didnt find any reviews about them: K tuned K2 circuit coilovers
K-Tuned K2 Circuit Coilovers - Honda S2000 AP1/AP2 Evasive Motorsports
they come with pretty high spring rates at 16k all round. but they offer custom spring rates so im initially thinking of getting 12k front and 10k rear.
any input and feedback is really appreciated.
These are more street oriented. But you can custom valve them for higher spring rates. With the grip levels the OP should be generating with his tires, id be looking in the 14/16k range if using near factory weight sways. Not sure how much custom valved DFV would be, but am sure more then 2k budget since off the shelf are already pushing it.
Ohlins is always the answer.
Thats why im inclined into the K2 from k tuned.. they already come with 16k springs and valved for that. And price wise they are cheaper than any other race coilovers.. and non s2k honda guys praise them alot. But i couldn't find any reviews of them on the s2000.. do you think its worth the risk?
I don't know much about them. Id like to know why they are cheaper. Is it because they are a single adjustable vs dual like the KW? If so, that's not necessary a bad thing as they typically last longer before blowing seals/no maint. But if you have honed in on your set up to really need seperate comp/rebound damping then that's another consideration. You will generally get more quality out of a single adjustable for the money/price point your shopping in if you can go without the added damping feature. Ive got about 150k miles on my buddy club race specs with 14 k rates with no custom valving as they are designed to run up to that from the box. Still no weeping seals. No KW has that record.
How do u rate your 14k springs? Do you think its fine or would prefer a softer/harder spring? Should i go for equal spring rates fron and rear? Or should i have it stiffer upfront to help keep the rear more stable?
Well said.. for the time being i think im fine with the single adjustability. I think illgo for the k tuned..
To be fair, you have an unorthodox setup But yeah, there are a lot of different setups that work.
