255/45/17 on 7.5 inch rim?
What do you guys think? I've googled a lot and found mixed feelings on this topic. Some say they are running the setup, others say your better off running 245's. What do you guys think?
Thanks, Juiced.
Thanks, Juiced.
i think that the minimum rim width possible is 8" for the 255 width tire. 9"is optimal and 10" is the max width for the 255 size.
so, 7.5? i wouldn't do it if i were you.
If you care about performance over looks, then I'd recomend the 245's. The 255's will allow the wheel to move around too much--it could even be dangerous on the track, not so much for autocross or cruising.
Depending on the tire, some 245's demand 8 inch or wider wheels so 255 is way too much for a 7.5 inch wheel.
