255 Square Setup Stock 01
Old 03-27-2015, 08:11 AM
blasphemy101's Avatar
I ran a square 255 setup using 4 rear AP2V1s on my '01. I believe they are 17x8.5 +55 +65, and I didn't have any issues with my unmodified fenders. I rubbed VERY lightly backing out of my driveway (over a curb) at full lock.
Old 03-27-2015, 10:25 AM
s2000Junky's Avatar
Originally Posted by blasphemy101
I ran a square 255 setup using 4 rear AP2V1s on my '01. I believe they are 17x8.5 +55, and I didn't have any issues with my unmodified fenders. I rubbed VERY lightly backing out of my driveway (over a curb) at full lock.
They are 8.5 +65 stock, but obviously if you did the 5mm spacer up front to clear the hub, then the front fitment would be +60 now.
Old 03-27-2015, 10:28 AM
s2000Junky's Avatar
I have no problem getting -2.5 camber up front on stock adjusters with a 13" ride height. There is more negative adjustment to be had as well, just didn’t want it. Not sure why camber joints would be needed unless you wanted like more then -3? The rear at 12.75" I’m maxed in the positive direction at -2.6.
Old 03-27-2015, 10:57 AM
Thanks for the correction. The rubbing wasn't an issue. It was extremely minor, so I didn't see any need for a spacer.
Old 03-27-2015, 11:10 AM
s2000Junky's Avatar
The 5mm spacer is just to clear the larger front hub, an alternative to boring out the rear wheel for front fitment, which some opt to do. I assume then that yours were bored out since your not running one.
Old 03-30-2015, 03:17 AM
tominboise's Avatar
I just put a set of TRM 17X9X63 and 255R40-17 RS-3's on my 2001 Friday and ran AutoX both days this weekend. Stock suspension with the exception of a Gendron front bar and alignment. Clearances were all fine and no fender work required.....
Old 03-30-2015, 04:41 AM
scottdh20's Avatar
you might have aftermarket adjusters in there...fronts max out right around or under 2*, mine were maxed at 1.8* up front.
Old 03-30-2015, 10:26 AM
Xene's Avatar
Originally Posted by KaNgArOo
Roll the fender tabs in the front at least. You will rob the inner wheels on the upper control arm with 17x9 +60. and also the outer edge fender liner.
I heard this may happen, but it is only during full lock of turning right with steering? Anyone have experiment with 17x9 +60mm offset wheels like Enkei PF01 with a STR ride height (12.75-13.25") and front fender tab rolling. Do you get this same issue as well?
Old 03-30-2015, 09:45 PM
S2000_916's Avatar
A little off topic...but my AP1 is bone stock, stock 16's with Rs3 on them. Camber is maxed out...-1.8 front, -2.1 rear. The snap oversteer was a bitch to deal with. Changed my rear sway bar to an Ap2 and the car is perfect. Rear still comes out, but it gives you warnings. Goodluck
Old 04-01-2015, 08:46 AM
s2000Junky's Avatar
Nope, stock adjusters, at 13" ride height. Maybe your at a higher ride height? I have 20mm bump correction spacers under the steering rack, but that shouldn’t influence camber adjustment throw.
Quick Reply: 255 Square Setup Stock 01
