5mm spacers = bad lugnuts?
If the nuts go on 5 turns and then start to bind, then it doesn't sound like cross-threading. Possibly the ends of the studs have stretched and the thread spacing changes abruptly at that point. That would cause binding, and would be a very good reason to replace the studs, whether or not you plan on getting longer ones.
I put 3mm spacers on and I still put longer studs in.
If you can't get 6 turns MINiMUM (i.e., 5 or 5 1/2 is not "close enough"), you need longer studs.
Also, torque to 80 lb-ft only! There is ZERO benefit to torquing them higher. Less thread-engagement PLUS excessive torque => you need new studs, all of them.
1 Post
All over torquing does is stretch the studs.
Originally Posted by street_ruler,Aug 21 2009, 01:01 PM
so with the need for longer studs, are there any open ended or longer/deeper lug nuts that can be used with stock wheels?
It's difficult to find aftermarket ball seat lug nuts. A friend of mine was able to purchase some adapter washers that let you use a flat tapered lug nut on a ball seat wheel. I think they were from a VW parts shop. VWs have ball seats but they use lug bolts instead of nuts and studs.
dan_uk
06-26-2009 09:19 AM
