949 Racing 6LU track setup help - S2KI Honda S2000 Forums
Notices
Old 09-11-2017, 10:10 PM
Frick26's Avatar
Default 949 Racing 6LU track setup help
Hey guys I'm planning on tracking my car a lot and I saw this set up on 949 racing's website and thought it would work out great. It's a square stance 17X9 +48 Front 17X9 +63 Rear with 255's all around. I am also gonna put the car on either eibach 1"race springs or H&R race springs. I was wondering if anyone is running a similar set up and what it took to get the set up to fit? I'm assuming I have to roll my fenders. Here is a link to the wheel
http://949racing.com/17x9-6UL.aspx
Here is a photo of the setup
Frick26 is offline
Old 09-11-2017, 10:40 PM
FWIW I would recommend going to 17x10 and doing the light fender rolling needed.
Rationale:
1:a 255 tire will be faster on a 10" wheel. Less tire deflection, better feel, more contact patch
2: You can rotate tires to get more life out of them.
3: If/when you get more into it, you will want 10" wheels eventually anyway. Why not start there and save money.
4: Less potential mistakes (tire shop monkeys putting the wrong offset on the wrong end, causing damage). OEM's prevent this with different hub diameters. IF you opt to stay with 9's order the 949 hub-centric rings and glue them in to prevent this
I own 2 sets of 17x10 949 wheels and am quite happy. Its a great product by a great company.
anorexicpoodle is offline
The Following 2 Users Say Thank You to anorexicpoodle For This Useful Post:
Chibo (09-20-2017), robrob (09-12-2017)
Old 09-12-2017, 02:36 AM
robrob's Avatar
I'd stick to the same offset front and rear so you can rotate your tires (anorexicpoodle's #2). This will save you a lot of tire dollars.
robrob is offline
Old 09-12-2017, 02:51 AM
freq's Avatar
I'd stay away from lowering springs.
But I'm still staggered so ....
freq is offline
Old 09-12-2017, 05:46 AM
Frick26's Avatar
Thank you to everyone for the quick response. I had originally thought about putting on 10" wheels but I was worried that I would have to do a lot of camber adjustments to make them fit. But if I don't need to major camber and only need a light amount of fender rolling well I'm happy with that
Frick26 is offline
Old 09-12-2017, 05:48 AM
Frick26's Avatar
Well I was hoping do some suspension work. If not race springs do you have any suggestions?
Frick26 is offline
Old 09-12-2017, 05:53 AM
freq's Avatar
Will you be driving the car to and from the track? Is this your daily as well? What tires do you plan on running? What is your experience level?
freq is offline
Old 09-12-2017, 06:49 AM
Frick26's Avatar
I will be driving it to and from the track but I have my oem wheels for that. My dad and I like going to the track together and he trailers his car so I can put those wheels in the bed of the truck, or I drive with the aftermarket wheels to and from. This is my daily but I'm not too worried about driving on my aftermarket wheels. I'm at a above average experience level. I'm not sure at this moment what tires ill be running, maybe Pilot Super sports.
Frick26 is offline
Old 09-12-2017, 09:11 AM
Frick26's Avatar
What if I want to run a staggered setup of
17X9(+48 or +55) & 17X10 +52 or 17X8 +48 & 17X9 +55? What kind of tire would I need to run. 235 F and 255R? What are some good sizes for staggered? The +55 is 949racing's s2000 suggested offset.
Frick26 is offline
Old 09-12-2017, 10:08 AM
I don't see the advantage of running 235/255 stagger with less than offset of +55
First of all you will need to roll your fenders just to clear the tire, not to mention you wouldn't be able to rotate tires.
I'd go 17x9 +55 square with 255/40/17 for simplicity and then get a good track alignment
gptoyz is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
