About to install my SPG with Taitec rails
So, I'm about to install a Recaro SPG with Taitec rails, is there anything I should know before hand before tackling this? Any tips? Do I need to do anything with the airbag sensor etc. etc.?
If anyone has a link to a thread with a general install for seats that would be cool. Thanks.
After installing mine with the BC rails I had thought of something. I wished I had measured the mounting holes on the floor, then spaced out the rails accordingly (outside of the car), then put the seat between the rails and added spacers between the side-mounts and the seat itself (since the seat is narrower than the mounting holes in the floor from what I can remember). Not sure if that works but it sounds like it would. Then you could bolt everything together outside of the car while keeping the proper spacing between the rails, drop it in, bolt it up and you're done.
It made sense in my head, but I hope I put it into words well and it actually makes sense
And thanks for the tip Disco.
gptoyz
09-06-2013 09:25 PM
