accusump plumbing
The check valve is so oil from the accusump feeds the block directly and quickly if there is cavitation of the pump or other oiling issues in the engine. Without the check valve the accusump will pump oil through the rest of the system as well as the block.
So I am trying to do a accusump setup with oil cooler right now and I am trying to make sure i get the right products. I have emailed Canton and haven't heard back. I PM'd DatsunDoc , and haven't heard back, so let me bring it to the group to see what i am needing.
Here is my part's list so far (amazon links for reference as it is easy, but will shop around)
Inline thermostat: Accusump:
I am sourcing a 15 to 30 row oil cooler (measuring space now to see largest that will fit) with a SPAL fan that will fit in the space available. Everything will be ran using AN-10 fittings and lines.
My big questions are:
- Do I need Check Valve? I am assuming yes and which is the best not to limit oil flow?
- Should I remove factory sandwich adapter ?
- What is the best aftermarket sandwich adapter to get? I need two plugs for oil pressure and oil temp.
- What is the benefit of spending the extra $200 on electronic pressure control valve?
- Is the mishimoto inline thermostat better than Mocal ? any other options I should consider?
wow this is a serious build, any more information on this car?
I sent you a PM. You can email me directly at DatsunDoc@aol.com
turbo8765
05-23-2014 12:37 PM
