The Actual S2000 Suspension Motion Ratios
SakeBomb,
Thanks so much for doing these measurements and sharing with the community! (I'd almost given up on anyone actually doing this!)
I hate to ask, but would you be willing to post (or just send me) the numerical data from your plots? The reason I ask is that, just eyeballing the curves and trying to read off the numbers, I actually calculate different MR's than you posted. For example, for the front bar, your data seem to show about 80mm of deflection over the course of about 150mm of wheel movement. That's an MR of 0.533, vs. your estimate of 0.492. The other plots also seem to result in higher MR's than you indicated.
Thanks again and best regards,
John
John
Hey Rob , miss you in the RX-7 world
That's a pretty common formula for wheel rate, you will often find some extra terms like an angle correction factor but that is do to the lever style MR measurement and isn't needed in this case.
Wikipedia Wheel Rate
Eibach Wheel Rate
You will sometimes find the equation written as WR = SR / MR^2 but that is with the MR being defined as wheel travel / spring travel instead of spring travel / wheel travel
Optimum G Upside Down Motion Ratio
Eibach Wheel Rate
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
Thanks SakeBomb for the links. My suspension spreadsheet does indeed have the motion ratios squared, I just forgot about it.
I have always applied the s2K's 20 degree shock angle to the wheel rate formula, what is your reasoning for excluding it? The more the shock lays over the lower its effective spring rate.
If you look at the Eibach link, their motion ratio term is really vertical damper bolt movement per wheel travel. The real definition of motion ratio is damper travel along it's axis / wheel travel. We measured the damper travel along its axis directly so the angle correction factor isn't needed.
The Eibach page defines the MR as d1/d2 but it's should really be d1/d2*cos(damper angle).
__________________
So to make sure I understand, you measured shock travel and wheel movement so your motion ratio isn't really d1/d2, so it won't be accurate when used with a shock angle factor like in my spreadsheet--unless you know to set the shock angle factor to 1.
Edited to remove "nonstandard."
SBG's measurements are along the correct dimensions to translate spring movement to wheel movement.
They've been kind enough to share more details with me via PM, and in turn I'll be sharing my thoughts here sometime soon.
I really appreciate SakeBomb sharing their data, I just want to make sure I and others understand them. If someone uses their motion ratio numbers (which are different from previous s2k measurements) then puts in a 20 degree shock angle correction their results will be incorrect.
So to make sure I understand, you measured shock travel and wheel movement so your motion ratio isn't really d1/d2, so it's non-standard and won't be accurate when used with a standard calculation that adds the shock angle factor like my spreadsheet--unless I know to set the shock angle factor to 1.
-SBG
__________________
