AiM Solo DL
Anyone using the Aim Solo DL to capture data? I couldn't find configurations specifically for the s2000, and tried to capture data this past weekend - didn't go so well. While I was able to get the basic information easily, OBDii data doesn't appear to have been collected.
Also, I'm trying to figure out how to plot/generate basic things, such as friction circle, etc. Any input, including links to tutorials or helpful documentation would be much appreciated.
2. Friction circle shows your lateral/longitudinal G forces - basically, how well are you using the cars braking/cornering grip capability. I see you can plot the lateral/long in a graph format, but looking to generate a circle like this
3. Air speed of unladen swallow would depend on if it's african or european...
Pretty good info over here by the way - http://www.trackhq.com/forums/f299/aim-solo-how-4526/
The basic stuff is pretty simple, but not sure how to get the OBD data sampling setup. I think I read somewhere that for the s2000, you need to set it to ECU Manufacturer = OBDii and Model = ISO. Will have to try that out.
Originally Posted by sheel' timestamp='1352306225' post='22135537
[quote name='GT Motoring II' timestamp='1352304701' post='22135476']
[/quote]
Nope, that shouldn't be the case... those E92s use CAN I believe. I think it's simply a matter of configuration on the DL itself that I don't have correct. and then from there, I need to figure out how to use Race Studio. The basic GPS Speed graph and mapping is pretty straight forward, but from there...
