Alignment thoughts
http://sphotos.xx.fbcdn.net/hphotos-...56191709_n.jpg
This is my tire leaning on its own from uneven wear. The left side is the outer edge. This is with -3.4 camber (front tire... rear looks similar). How much more camber should I add? I don't have a pyrometer, but the wear is pretty clear. This tire is also street driven, and camber wear isn't too much of an issue. Specs: OEM CR suspension 17x8.5 rims 255/40/17 RS3 -3.4 camber front, -3.5 camber rear |
just to clarify - you get more wear on the outside?
Originally Posted by Croc
(Post 21769720)
Saw the tire myself, it's clear he needs more camber (I suppose technically it's less camber). |
i need more also
how r u achieving 3.5 rear? |
Originally Posted by Living in the redline
(Post 21769967)
i need more also
(Post 21769720)
In the background, you can see the same wear pattern on the rear left. |
Looks like you do need more camber. My hunch is part of it has to do with the 8.5" wide wheel. I bet your camber would be more than enough if you were running 9 or 9.5" wheels.
| All times are GMT -8. The time now is 07:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
