Alignment went off after track day
Heres the alignment I got today. So after hitting the dirt, the camber and toe def moved as you can see with the before specs. The shop was able to get it to the new specs I want but Im seeing a different spec for SAI and included angle. Frome thses numbers, is it a big possibility something got slightly bent like knuckles or LCAs?
Potentially there could be something bent, but I would check the sub frame alignment first and also eyeball the bushings first before worrying about bent pieces. How many miles are on the car? Judging by the before and after, you went off right side leading the way and possibly hard enough that you could have shifted the subframe a minute amount.
In an ideal world, they should be just about the same left to right, but there's a number of things that can throw that off. With how you left the surface, you would expect the difference to be reversed between the left and right, but no telling over the internet. Visual inspection would be the place to start and if nothing is obvious and it's not causing any issues with handling, don't worry about it.
