AP1 to AP2 rear subframe/suspension conversion?
Old Oct 22, 2014 | 04:47 AM
dan_uk's Avatar
Default AP1 to AP2 rear subframe/suspension conversion?
has anyone changed the rear subframe and control arms to the ap2 setup with the reduced bumpsteer?
any better/ worse?
I have no real problem with the ap1 my cars pretty dialed in right now but it could probably use a new rear subframe with the left rear being crashed about 3 times
I've heard people saying they preferred the ap1 setup
Old Oct 22, 2014 | 11:53 AM
dc50818's Avatar
any better/ worse?
I dont think u would really notice a difference with aftermarket suspension on the vehicle
Old Oct 23, 2014 | 11:04 AM
SC_Highlander's Avatar
I already had the TC Design anti-bumpsteer kit (toe arms) when I did my AP2 conversion. I honestly didn't notice any real difference between the two.
Old Nov 11, 2014 | 04:34 PM
Sylvain2000's Avatar
That is interesting. You make it sound like it was not worth it.
I guess those antibumpsteer makes a good diference then ??
Sent from my iPhone using Tapatalk
Old Nov 15, 2014 | 04:14 AM
Slowcrash_101's Avatar
The biggest and only real difference is that Ap2 the upper control arm mounting points are further apart than on Ap1. This means that the control arm bushings have less force acting on them perpendicular to their normal motion. They did this to minimize toe change in the rear under braking and acceleration. This is why Ap2 seems more forgiving, Ap1 seems sharper. In either case it's a moot point if you have spherical bushings.
Old Nov 15, 2014 | 05:26 PM
Dead Serious's Avatar
I bet this is why the energy/prothane bushings i tried to install today didnt fit the rear upper control arms.
taylor
Oct 13, 2011 04:08 AM
Bullwings
Oct 14, 2010 11:01 PM
tonerockyhorror
Jun 29, 2007 07:38 PM
BAMbam160
Mar 2, 2007 07:48 AM
