Baero BBK Do-It-Yourself Wilwood Kit - Group Buy
Batch 2 is now in production and ready to preorder: https://baero.tech/s2000-brakes/diy-wilwood-bbk
A few forum members have reached out to me to develop a DIY BBK kit for our S2000. I have done with for a few cars already in the past so I know the logistics of making it happen. For the money it is a great kit and gives the power to the consumer. Many companies make a profit by operating as the middle man, so that would be eliminated and transferred to you.
In order to make a batch, we need a group of 10 people to get pricing to work. A set of rotor hats and brackets would be provided, then you would piece the rest of the kit together. The rotor hats and hardware are $400 for a set. This includes mounting hardware. The kit would work as a pre-order so payment will be required up front. Since this requires a large batch to get good pricing, this kit will not be for sale on my website full-time, but offered as a one-time batch.
This kit is designed for the following parts:
Calipers: Wilwood Forged Superlite - $350 - https://www.summitracing.com/parts/wil-120-11130
Brake Lines: Wilwood Brake Line Kit - $80 - https://www.wilwood.com/linekits/lin...emno=220-10841
Rotor Rings: AP Racing 325x32mm Rotors - $500 - https://www.essexparts.com/ap-racing...-rings-32532LH ; https://www.essexparts.com/ap-racing-j-hook-rings-32532
Rotor Hat Hardware - AP Racing - $50 - https://www.essexparts.com/10bolt-disc-hardware-kit
Pads - Hawk DTC60 (as an example) - $153 - https://www.ebay.com/itm/Hawk-DTC-60...YAAOSwYIxX2e7X
By buying the consumable parts yourself, this kit is ~$500 cheaper than comparable sets on the market. This is the kit I have ran for over 10 years on numerous cars and it works flawlessly. I am on the end of year 2 on the same set of rotor rings (~60 track days so far). I just changed my pads for the first time in 2 years. Wilwood uses a 20mm pad shape which is super common. They last a long time and are really cheap. I use the 1.38" piston diameter calipers, but the beauty of this kit is you can buy the bigger pistons if it suits your platform better.
The rotor hat and bracket will be made of 6061-T651 aluminum. The bracket will have helicoils installed so you don't have to worry about ruining the threads with steel bolts.
Group buy slots:
1. Roel03
2. @HawkeyeGeoff (paid)
3. @stewpitt (paid) 9405509699937836345817
4. @mpoganski (paid) 9405509699937836345831
5. @spaded.racer (paid) 9405509699937836345800
6. @ncrx (paid) CH078446793US
7. @Nate Tempest (paid) CH078447989US
8. @Joey Nguyen (paid) 9405509699937836345824
9. @Zer0ne (paid) 9405509699937836345855
10. @nb12 (paid) 9405509699937836345862
Assembly with Wilwood Superlite and 325mm Rotor:
3D View of Mounting Bracket:
3D View of Rotor Hat:
Group buy slots:
1. Roel03
The following 2 users liked this post by roel03:
freq (08-29-2019),
HawkeyeGeoff (08-15-2019)
freq (08-15-2019)
Neither of my current square setups will work with this. I'm still on OEM wheels studs so spacers aren't an option either.
Was curious if my current wheels would work with these with a small spacer but ti doesn't seem like it.
Brake bias?
What is the percentage shift F/R if any?
Asking for everyone else - i'm happy with my current BBK and am not in the market for replacing it.
This is such a good deal I'm tempted by it even though I already have a Stoptech bbk!
HawkeyeGeoff (08-16-2019)
With the smaller 35mm pistons the bias will be shifted 5% to the rear, the larger 41mm pistons gives 30% more to the front.
Use this spreadsheet to check for yourself, this seems to be same spec as the SKB kit.
https://docs.google.com/spreadsheets/d/1QB-R9Mz0Pehm_MudPWQWM67ua1XxktuQcJq6tPJIKjk/
