Bent 17x10 6ULs
Old 05-15-2018, 06:36 PM
Chibo's Avatar
I posted it on the Facebook post, but most of these affordable, yet lightweight track wheels are known for failures. n-thing that wheels are absolutely consumables and should be inspected regularly when tracked, especially on r-comps. Tire Rack even went to the effort of posting an article about it: https://www.tirerack.com/tires/tiret...jsp?techid=110
Some wheels are absolutely notorious for it, like the Kosei K1 cracking spokes, Fiskes cracking barrels, and OE C7 Corvette wheels cracking spokes.
Old 05-16-2018, 10:09 AM
Ricky_Flowers_'s Avatar
I used to be on the cheap, quality, lightweight cast track wheel plan myself. After turning a set of RPF-1s into hexagons after.... 6 track days? My "beater" track wheels are CE28Ns now. 7 full days on R-comps and they're still absolutely perfect.
In my experience, however, not all cast wheels are created equally. My old Enkei NT03+Ms had well over 15 days on them, and they never bent or cracked. When I finally sold them, the only evidence of them being used as track wheels was the brake dust haha.
Kami Speed (05-16-2018)
Old 05-17-2018, 11:47 AM
AlpineFD's Avatar
Originally Posted by Chibo
Do they need a spacer to clear a ST40?
i haven't tested my self, but the spokes does allow plenty of clearance, it bents outwards than inward toward the edge. (just alittle, not alot) the spokes are very beefy, there is a little bowl machined out in the center(back of the spoke), i guess to reduce the weight and rotational mass.
Old 05-18-2018, 03:01 AM
imstimpy's Avatar
Like your brake thread, I'll follow by saying I've had very similar experiences. I started with a set of 17x9 6ULRs and CE28Ns. After five years of autocrossing and 15-20 days of tracking, the 949s were bent while the CE28Ns were still perfectly round. I have since made the switch to 10" wheels.
From the unboxing I realized the 949 6ULs were not for me. The 949s are built to lower tolerances and less load rating compared to a Wedsport SA72R. As such, the roundness and the finish are visibly imperfect. They are certainly affordable, but you get what you pay for. Though the SA72R is heavier (~20lbs vs ~18lbs), I have a lot more confidence in my wheel choice. Every one of them came out of the box perfectly round and well finished. I'm six days, or 15 hours, into my Wedsport SA-72R 17x10+55 and they still remain perfect.
Old 05-19-2018, 01:58 PM
usafstud's Avatar
how is the Stoptech BBK, chassis and suspension clearance for Wedsport SA-72R 17x10+55?
Old 05-19-2018, 03:20 PM
Bullwings's Avatar
Yeah, they clear with more space than that!
I found this from the "official stoptech bbk wheel fitment" thread.
I'm actually going to order up a set. The 949 6UL group buy from THmotorsports is experiencing "overseas manufacturing issues." So, I cancelled my order. I'll spend an extra $250 and grab a set of these instead.
Old 05-19-2018, 04:37 PM
usafstud's Avatar
I’m in the same boat on the 6ul’s i ordered in feb. I’m hoping the +55 offset will work with the spc upper ball joint. I’m currently rubbing inside by chassis fenderliner with -3 degree camber with 17x10s +52 offsets forgestars on 255s
Old 05-19-2018, 07:39 PM
decepticondc5's Avatar
Those Wedsport SA-72R 17x10+55 are looking like a very attractive options as well. That wheel hasn't really come up my radar until now. They state that they are compatible with m14 studs; does anyone know if that means we need a special lug nut or something for our m12?
Old 05-21-2018, 07:38 AM
imstimpy's Avatar
I opted for a high offset wheel (+55) to stay off the fenders as much as possible. That said I do have upper offset bushings to keep the top of the tire inside the front fender, rolled front fenders, rolled/pulled rear fenders, and the rear bumper tab relocation. Finally, I added the Mustang steering rack limiters to keep the wheel off the inside fender. I definitively fit 255 R888Rs, 255 RE-71Rs, 225 R7s, and 245 R7s without rubbing at a 13.25" rear ride height. I suspect a 275 will need some additional fender work as it is taller and wider.
I am using the wheels with the standard ARP studs up front and MSI studs out back and my trusty SR48 lugs. I don't know what the M14 note is about but I don't have problems with the standard stud size.
Old 05-21-2018, 12:19 PM
Sickdayracing's Avatar
I bought a set of SA72R from Phils Tire Service and had them delivered track side. Had them on for Hyperfest and they worked great. 17x9.5 fits no problem over ST40s.
Quick Reply: Bent 17x10 6ULs
