Best roll bar for a tall person
#21
Sparco Sprint actually, though I may upgrade to an Evo II when my harnesses and seat hit their “expiration” date or whatever it’s called. I don’t actually mind the steel frame seat as there is enough padding for comfort and being a steel frame I was able to “massage” the shoulder wings a little to fit me slightly better
#22
Would you pass the broomstick test with your helmet on? Looks like it would be close. Asking because I've been working for a while on getting a seat in the car low enough for the rollbar to be safely over my head.
#23
#24
#25
LouisvilleNFR, do you drive that car on the street? To the track?
#26
Yes, I do pass with a helmet on, though it is close. The seat and mounting has more to do with it than anything. I have no rails or sliders, mounted directly to the floor. There may be 1 inch clearance from the bottom of the seat to the floor on the rear. I probably gained 2-3 inches of headroom over stock. Since that seat is cloth/springs on the base, your butt sinks a little lower than the actual bottom of the seat when you are totally strapped in.
When my harnesses are on they hang just above dead center in the harness slots, and I’ve been told I have a long torso. The holes are about 4” tall so that gives plenty of room for many driver sizes. The shoulder wings are very narrow, but if you take the seat cover off, a long 2x4 can “massage” the wings into a much more comfortable position
#27
I don’t drive it often, but it has plates on it, so it does get driven on the street occasionally and to the track. I know 6-point harnesses and race seats aren’t considered street-safe and the rollbar has the super-stiff SFI padding on the exposed areas.
Safety concerns aside it’s actually not as uncomfortable as you’d imagine since I don’t have to slouch down in the seat to clear the roof anymore.
#28
I winced when I saw how close your head is to the rollbar.
#29
That photo makes it look closer than it actually is, especially with the thick pad on it. Head to bar clearance is probably 3-4 inches at the closest point. When I still had the soft top, my head was much closer to the soft top hinges over the door than the roll bar and my helmet would sometimes make contact with them over rough spots on the track. I know they are not quite as unyielding as the roll bar, but no one ever seems to worry about those when discussing helmetless driving safety.
Anyways, finally got a few more pictures for the OP, first is helmetless clearances, second is how close the broomstick (yardstick in this case) test is. If you want any specific pictures just ask and I’ll do my best to get them.
Broomstick test
Broomstick test
