Brakes spongy.. Will they stiffen?
i am encountering the same problem, i can simply not get rid of the sponginess after multiple attempts at bleeding, and gravity bleeding.. i let air get in the master cylinder as i took off my calipers, and let the fluid run completely dry. how many times is necessary to get rid of the air?
When I switched brake lines, I noticed that no matter how many times I bled, the sponginess wouldn't go away. So I drove around for a few days (very carefully), then bled again. Then drove a few more days, then bled again. The pedal got successively better. I might try activating the ABS and bleeding yet again.
Yeah, I think the parts just weaken over time, and these millimeters of flex adds up to increased sponginess. Whenever I drive my friends' CRs, I get so jealous of their pedal feel. But in the end, you mash it down as hard as you can, you still stop just as fast.
Interesting, I swapped my brake lines and calipers last night. But didn't get any air in the system, I only let a few drips of fluid out per wheel and I topped up each time.
Still felt spongy as all hell. So I drove around a bit activated ABS and it stops well just felt crappy. So I bled a little again no air.
I find after I change them they always feel spongy though and they stiffen up after a while.... or I get use to it....
Pay attention to the size of the orifice on aftermarket brake lines compared to stock. I have witnessed one very popular company selling stainless steel jacketed brake lines with a much smaller hole leading into the banjo fitting. Let's just say they were promptly returned.
Sdracing, thanks for the website plug
Bleeding the Master Cylinder
