Is this a BSK?
Is this a BSK?
Description: Comptech Rear Adj. Camber (2 deg.) Honda Lowering your vehicle causes a condition termed ?negative camber ?.This is when the top of the tire leans inwards to the vehicle.Most vehicles have no factory adjustment to correct this condition.These camber adjusters allow the necessary corrections to regain proper alignment. Camber adjuster, rear -2 to +3 degrees Uses a rubber bushing for a quieter ride. One kit per wheel (two per car) https://www.s2ki.com/forums/index.ph...age&img=350121 |
The item in the pic on the right is a adjustable upper arm for a civic/integra.
lol, is that a HPI savage suspension?
If you want a bump steer kit for the S2000, you can only get it from gofastlab.com
Same one but different site. |
tc makes them for GFL
Originally Posted by ellisnc,Aug 25 2006, 04:00 AM
There's also about 5 different Japanese companies that make them...
I haven't seen any rear ones before.
Care to provide some links? Edit: Spoon, for example, is all front end parts. |
