Can I get anymore life out of this tire
You can run tires backwards if it isn't going to rain. It makes zero performance difference in the dry. So you can move the more-worn tires over to the side of the car that will see less cornering stress for your track. Personally I've run track days on RS3s that looked worse than that and they were fine at the end. But YMMV and you might enjoy the performance of the fresh RE71Rs.
HawkeyeGeoff (06-13-2018)
You think more camber based on that uneven wear?
The only time I drive on the street is too and from the track. Admittedly I have forgot to pressure back up before heading home a few times.
I want to say I have around 20hrs on the tires, I was hoping to get more. I went with 71rs in hopes of making it to the end of the season, which would be roughly 20hrs, I don’t think the 71rs will make it if I swap now.
No and I just realized that by more camber you mean more positive camber, not more negative, which is why I was confused. I have not hit them with a pyrometer, but I should. I think I have -2.6 which isn’t crazy though. That said maybe my alignment is actually off, I have spun a couple times and haven’t checked it since. I am thinking I should just bite the bullet and put the RE71s on/get the car aligned. I just really wanted them more fresh for my late events! Any idea how much faster the RE71s will wear?
I'd run those.
HawkeyeGeoff (06-14-2018)
freq (06-14-2018)
Looks like you're running too much toe. Both, excessive in or out, will do that to a tire.
Either way, very little of the inner tire gets used on track. I run my tires till they cord. :P
