In-Car Video Setup
#22
I have also jumped on the 2 cam set up
using the piciture-in-picicture box as well(branded by Chasecam)
i record into DV or microMV cam that is mounted secure on the typical rollbar mount u would use in a traditional in-car single camera
works very well so far
very wide angle, almost fisheye lipstick lens, front cam gets full view of driver, road ahead and front steering angle
#23
another option for if you want to hardmount somewhere and have a separate monitor available for checking the cams.
http://www.neurosaudio.com/store/prod_recorder.asp
30fps mpeg4 352x240 (TV res)
sd or cf
user selectable quality
use one for each source. put a multi pole relay somewhere inline w/ each of the video feeds. use the relay to switch off the video signals (not power to the cameras) for a second or two all at once, instant blank reference point in all the videos for syncing later.
sd or cf
#25
sd or cf
sd or cf
It's terrible for four reasons: It has no monitor, so it's a pain to check if your camera is working or is positioned correctly. It doesn't even have a 'recording' light, so you need to attach a monitor just to see if you're taping. It can only be operated by a remote control, which you have to find a place for in your race car. And finally, it has no battery, so if you turn the car off without re-connecting the monitor to confirm that you've turned off the recorder, you lose everything you've taped. Worse still, it loses the recording if you crash and the power is interrputed, so its 'black box' value is nil.
If anyone wants one, I'll sell mine cheap.
#27
Anyone have experience with the Audiovox PVR1000? I just bought a new one off eBay for $60. For that price, I thought it was worth trying.
http://www.shoptronics.com/aupvpopemepl.html
#29
Originally Posted by Haulin' S,Jan 5 2006, 01:03 AM
Has anyone come up with an 12v DC power supply for the cameras that runs off the vehicle's electrical system? If so, how'd you do it?
