Carbotech up front Stock in the rear?
I'm on stock tires and my07 does have rear bias but is hindered by abs. I run 12/8 just so abs isn't always on in the rear under heavy braking zones.
I ran new rear pads in the rear with 8's up front at my first track day and they were gone on the 5th session.
How do you like the 12/8 combo? I might order 12's myself because I'm running 255 RE01R upfront. After a massive spin at streets (ask Mark), which cost me a set of tires, I think I want to bring the bias forward a bit.
Originally Posted by 600rr_rocket,Jul 24 2009, 11:57 AM
The OEMs were completely destroyed and the pistons put deep grooves into the rotors.
btw you can use a 3/8 ratchet to turn the piston back in if you don't have the tool or forget to bring it. Future info.
Originally Posted by Antonov,Jul 24 2009, 12:53 PM
Hard to beat this community!
Originally Posted by macr88,Jul 24 2009, 11:59 AM
WOW!! You went through the friction material, backing plate and then worked on the pistons in two sessions? Damn!!
I used to use the 3/8" to do my rears, but after so many pads changes, the metal corners facing the center of the piston warped and I couldn't use it anymore. That's when I went to Autozone and bought this for ~$7,
Originally Posted by VitaRenovatio,Jul 24 2009, 12:14 PM
^ How can we expect to use that tool if it can't even fit in the car!? The tool has to be at least ... three times as small.
