Compliance Bushing Dimensions
Could someone please put a caliper on the inside diameter of the metal sleeve of the compliance bushing. Alternatively if I knew the outside diameter of the caster adjuster sleeve that goes up through the compliance bushing I could figure out what I need. Thanks.
I got an old pressed out oem compliance bushing that I just checked.
You do mean the inside diameter where the adjuster sleeve goes through? On mine that is 20.0 mm. |
Perfect, thanks. i guessed it was 20mm holding the adjuster in my mind. The MacGyver is strong with this one.
