Corbeau Forza Sport install and review
14 Attachment(s)
Hey guys, I posted this over in my build thread in the Gallery section, but wanted to share this here for those who might be in the same boat I was.
So as I've been tracking the car more and more, started to feel the that the stock seats were no longer cutting it. To try and stay in place I was having to brace myself with my knees, and this in turn made it difficult to be precise with my brake and throttle inputs. Only issue here is that the majority of the aftermarket seats that fit the S2000, don't fit me. I am what you could call "fluffy" (6'0" 280lbs 42" waist) and as you can imagine my options were extremely limited. I had tried several different seats: Recaro PP (barely fit, but harness holes are too low), Sparco EvoII US (fit decent, but requires extensive work to fit the car), and looked at ordering the Marrad ST3 (which are copies of the Recaro Pole Position ABE which are a little wider than the regular PP and have larger harness holes, but have no FIA or SFI certification). During my last track day with Track Night in America, one of the local S2000 guys had recently installed a Corbeau Forza Sport and I asked if I could sit in it. The seat fit me good (about the same as the Sparco EvoII US) is FIA certified, had proper harness holes, cost less than half of the Sparco and Recaro options, and best of all fit the S2000 with no modifications needed! So I decided to order the seat along with the Corbeau seat brackets with double locking sliders. Ordered the seats from THMotorsports who had the lowest price and also offered free shipping. The seat arrived one week after I ordered it, shipped directly from Corbeau Attachment 74710 Attachment 74711 The seat was packaged very well, it included the seat brackets in the box which are very well made with thick steel and pre-drilled for the S2000. Attachment 74712 The bracket install was very straightforward, the Forza Sport comes with options to either do a side mount or bottom mount, the Corbeau seat brackets use the bottom mounting option. To install just remove the 4 hex mounting bolts on the bottom of the seat, align with the holes in the slider and install. I did the forward two bolts first, snugged the bolts but didn't tighten all the way, then slid the slider forward and installed the back two bolts. After everything was installed, I tightened the four bolts properly. Attachment 74713 The brackets also include a place to mount the OEM seatbelt, which some aftermarket brackets do not, I will need to use a seat extender to allow access to the seat belt as there is virtually no space between the seat and the transmission tunnel. Attachment 74714 Bracket install took maybe 10 minutes total, and the seat was ready to go in the car Attachment 74715 Here's a closeup of the seat and materials, it has good padding and the cloth like material seems to be good quality, I would say equal to what you get on a Sparco seat. There is also an option for vinyl "leather" and a few different cloth color options as well. Attachment 74716 FIA certification Attachment 74717 Side by side with the stock seat, I measured the space between the floor and the bottom of the seat and on the OEM it is 5" and the Corbeau is 4" Attachment 74718 The seat install itself was very simple, I've read horror stories of installing aftermarket seats and how difficult it is, but with the Corbeau brackets, everything lined up perfectly out of the box. I pushed the seat slider all the way back and installed the front two bolts first but left them loose. Then pushed the seat all the way forward and using a long 3/8 extension easily bolted the back two bolts. Total install time, including removal of the stock seat and moving over the OEM seatbelt buckle was 45 minutes. Here are some pics of the seat installed: Attachment 74719 Attachment 74720 Attachment 74721 You retain full use of the center console which clears the seat by about 1/8". The left wing of the seat does touch the side plastic just behind the door, but just barely. Attachment 74722 Before the install I took some pictures and measurements of myself in the seat with my helmet, just give some idea of how low the seat fits. With both seats pushed all the way back, the OEM seat was 40" from the floor of the car to the top of my head, the Corbeau seat was just under 39". So with this seat you also gain a little over an inch of headroom. In the picture the top is the Corbeau seat, bottom is the stock seat. Attachment 74723 Since I am happy with the seat and the ease of installation, I went ahead and ordered another for the passenger side as well. Had the wife try it out, and even though she is much smaller than me, she felt comfortable in the seat and said it felt much more supportive than the stock seat. Hopefully this helps some others in a similar situations, if anyone has any questions about the seat or the install, let me know! Link to the seat on the Corbeau website: Forza Sport - Corbeau Racing Seats http://corbeau.com/media/catalog/pro...sport-la_2.jpg |
Nice review, glad to see how easy the installation was. Have you had the chance to spend a longer period in the seat? Curious how it would feel after an hour or two drive.
Originally Posted by Nhil
(Post 24193562)
Thanks for the write up. Not to put you on the spot, but any chance you can post a picture from an angle to shows how you fit in the seat? I'm 230lbs with a 39" waist and I've been trying to find a seat that I will fit in, that won't crush the life out of me or get uncomfortable quickly.
Originally Posted by Fokker
(Post 24193591)
3 Attachment(s)
Finally got a chance to take some pictures of me in the seat with the seat belt buckled (extender didn't arrive till today). There's not a ton of room to take pictures, but here you can see how the seat fits around my shoulders, its very snug but not uncomfortable. Will take it for a spin soon and report back with driving impressions, also have a track day next week (May 5th) so should have some info from that as well. The passenger side seat should arrive by Thursday, so will be installing that one next.
Attachment 74614 Attachment 74615 Attachment 74616 |
Did this come with everything needed for install or the brackets separate from the sliders?
Originally Posted by S_DosMil
(Post 24197042)
Thanks for the pictures. How does it feel in the hip area?
(Post 24197286)
