Corner-weighted
I had my car corner-weighted and aligned today. I'm curious about how good a job they did. My weights came out as follows:
753 727
724 697
Wouldn't it be better if they were the same at every wheel? I'm guessing that they would be pretty difficult to get that way. That was done with half a tank of gas and about 140lbs in the driver seat.
753 727
724 697
I've heard that the diagonals need to be close, not side to side or all 4, though all 4 the same is the ideal.
I'd go back and fill the tank, that will add more weight to the rear and ballance out the RR and LF diagonal weights.
it will be very hard to get the corners equal you can spend days trying to get it with in 2-3 lbs close to each other. the idea is to get the Cross weights 50/50 and the front to back as close as to 50/50 as possible.
was this done with you sitting in the car?
