crank pulley.. wear item?
ATI is either 10% underdrive or 7% overdrive for the street version.
Not sure why you would want to change the ratio but I read it was designed for another engine so that might be the reason.
I would probably go for the Fluidamper instead Fluidampr URGE designs
Yes, the ATI race version which is 10% underdriven won't clear the factory water pump pulley so either custom WP pulley must be used or some other form of external water pump must be fitted. The advantage of an underdriven dampner is that it is less drag on the engine. Now the overdriven street version can be beneficial to the supercharged crowd out there in allowing them to make a little bit more boost by changing the pulley ratio from the bottom end not just the top.
Just thought I'd update this thread, my pulley has failed and has started to get a wobble on when the engine/motor is running.
For the record my car is SC'ed, I think the CT pulley that mounts onto the OEM pulley has caused it.
Just wish there was any after market one that worked with SC'ed cars
Well that is the first tome i read about a bad crank pulley!!
Good to know!!
As i was going trought this thread i really tought this had kind of never happen. But there it is.
Thanks for sharing!!!
Was there any sign before it got bad ??
Good to know!!
I put one through the hood of my BMW 335D at 40k miles.
