Do Hoosiers Break Wheels?
lol hoosiers don't break wheels.... unless (enter your reasoning here). I hit apexes very hard with my rpf1s and go airborne. If that doesn't break the wheel, tires surly will not.
Ive been hearing wheels are a wear item since i started tracking ten years ago. Im interested to hear if increased traction levels significantly decrease the life of a wheel. I suspect it does. Im also interested to hear if catastrophic failure waits for me at the end of the wheels life or just some bending and runout. Valuable contribution to this thread sounds like. "I had a wheel break. I was caused by this and that"
Impact can certainly break wheels, but the more common failure (by far, and more insidiously!) is fatigue failure. All aluminum wheels will fatigue and crack, eventually, regardless of the tire used. It's caused by the cyclical loading of the rim with respect to the hub (during cornering, the rim is getting bent towards the centerline of the car at the bottom, and then pushed back away when it rolls to the top, so every spoke gets a stress reversal with every rotation during cornering).
Aluminum has a finite fatigue life, so literally every wheel will eventually fatigue crack and fail. It comes down to numbers--a high end racing wheel running the hardest eco tires may have fatigue life in the thousands of years, and a poorly designed wheel on super soft competition tires may have a fatigue life of days or hours.
For ~~enthuuuusiasts~~ like us, the fatigue life of our wheels is essentially unknowable. If you run sticky tires, inspect for cracks more often, that's about all you can practically do.
I rotate after almost every track day, and inspect each time. I cracked a 949 17x10 gen 1 ulr.
-8 year old wheels.
-3rd owner
-past two owners tracked these wheels also
Cracked the inner lip of that passenger side front (spokes were fine).
I'm pretty sure it happened here entering cotton corners at BW cw13.
Start at 0:38 seconds.
