Downforce front fenders
Hey guys and gals, I’m looking at some square wheels, 17x9 +45 offset. I would like to keep my stock oem fenders in original condition. I would consider a very minimal roll, but I would prefer to keep the fender liner in tact. I am considering origin front control arm bushings and perhaps some lower offset joints to maximize the camber and fender clearance. Is this possible to fit without fender damage? fun part, I have a steep driveway which requires entry at an angle and a little suspension articulation in order to avoid scraping my front end. This is with my staggered ce28 in 17x7.5 +5? Offset https://cimg1.ibsrv.net/gimg/www.s2k...b8f92e734.jpeg I can’t fit a finger in there.... Sooo ....in come the various options of wide front fenders. I know there’s a few options one being Downforce. Im wondering what is the easy, durable, most cost effective option for wide front fenders? How do the various fenders incorporate the stock fender liner which I’d prefer to retain? I know, I’m asking to have my cake and to eat it too. I want the wide rubber up front 245-255. So gotta do 8.5-9 inch wheels and I don’t really like the idea of 60+ offset, just personal preference. Thanks in advance!!! Casey |
Raise your car. :)
You really have the ideal set of staggered wheels, why the burning desire to go square? |
Originally Posted by freq
(Post 24550965)
Raise your car. :)
You really have the ideal set of staggered wheels, why the burning desire to go square? 2)I’m going to start doing track days and I’m not sure I want to chance tearing up the volks. 3) I came from a 135i where the fenders are also limiting factors for front tire, so I’m a glutton for punishment, and I hate understeer Id entertain keeping them as well but also just curious what’s possible |
Originally Posted by Tsxtx
(Post 24550962)
I want the wide rubber up front 245-255. So gotta do 8.5-9 inch wheels and I don’t really like the idea of 60+ offset, just personal preference. |
Volks were made for the track.
If you're just doing a couple of days / year then just keep them clean and keep them protected. Good luck in your search and stay safe. |
I run a 17x9 +42 square setup with 255/40/17 and I'm still on the OEM fender and using the fenders liners. I had to roll the fenders slightly. I'm dropped on HKS SPIV coilovers on the setting that HKS setup from the factory. I still have roll to pull the fender if I want to get a more aggressive setup in the future. I can look for my alignment spec sheet if you need it.
I don't think you need to get a wider fender unless you want to. |
Originally Posted by tut4u2
(Post 24551105)
I don't think you need to get a wider fender unless you want to. How much negative camber are you running up front? I am running 17x9 +60 wheels on 255/40 running -3 camber and at the track/autox my tires have mangled my fender liners a little. Maybe this is because I am still on stock springs/shocks and they are soft, but I don't know. |
So I’m leaning towards a 17x9 +49. I’m currently on Ohlins with out of the box spring rates lowered probably an inch from stock.. I’m planning on a 245/40/17 up front and a 255/40 rear. Camber currently is only -1.5, I plan to have this adjusted to a max camber ~2.5-3. I’m also going to use the origin front upper control arm bushings which indicate an additional 7mm of increased fender clearance. Im hopefully of this being enough to net me plenty of clearance. It will be several weeks or a month before all that is put together (wheels/tires/bushings). I’ll report back once that happens. |
Originally Posted by exigex
(Post 24551717)
You haven't had any issues on track/autox with that setup?
(Post 24551105)
